aye lol go and tell Pete that he knows nothing, see how well that goes down lol
Tbh I was more Paul who said it in the first place. Negative Ba$tard!
the guy that put filler on and got it all wet should hang his head in shame.
Well I refitted the valves tonight and set the clearences :)
Only had to grind one shim to :D
Here is the Head built up..
https://fbcdn-sphotos-a.akamaihd.net...69485766_n.jpg
https://fbcdn-sphotos-a.akamaihd.net...83516908_n.jpg
And my new Fancy Inlet, its a Td lower with a redrilled N/a upper and the inlet pipe extended. Look good and should flow better to :)
https://fbcdn-sphotos-a.akamaihd.net...04956128_n.jpg
As you can see it should flow nice.
https://fbcdn-sphotos-a.akamaihd.net...00098560_n.jpg
I Spent a while wire wheeling the lower half then I gave it a coat of primer.
https://fbcdn-sphotos-a.akamaihd.net...80505081_n.jpg
That will do for tonight I think.
You do realise Primer is just a porous as Filler. It rained heavily for 20 minutes, we sheeted the car down and afterwards I removed the sheet, took the photo and then dried it off and covered over with a PVC sheet and tape.
I can hardly prime the panel when its raining.
Me and the people helping with the build are experienced enough and qualified enough to know what to do in these situations and have done many other projects over the years! Thanks for the advice though.
Well yesterday I stripped my other shaft out.
https://fbcdn-sphotos-a.akamaihd.net...68767190_n.jpg
Wire wheeled one Cv, they both need painting now.
https://fbcdn-sphotos-a.akamaihd.net...41253744_n.jpg
And today I came home and finished all the front end of the welding. I.e. splash gaurds, towing eye and battery clamp stud.
Very happy about this :)
Here is a few pics :)
Splash gaurds..
https://fbcdn-sphotos-a.akamaihd.net...30810830_n.jpg
https://fbcdn-sphotos-a.akamaihd.net...87006183_n.jpg
Towing eye nut..
https://fbcdn-sphotos-a.akamaihd.net...18478906_n.jpg
Clamp stud
https://fbcdn-sphotos-a.akamaihd.net...13912705_n.jpg
Hoping to get the welding done this weekend.. Fingers crossed!
Dan
Well Small update, Had the ode Man bead blast a few things for me,
Sump.
https://fbcdn-sphotos-a.akamaihd.net...33181375_n.jpg
I gave it a 3 coats of high heat silver, just waiting on a few other things from him then I can crack the spray gun out and do everything at once :)
https://fbcdn-sphotos-a.akamaihd.net...05039768_n.jpg
Dan
