looking good James
looking good James
A excellent all round effort fella... You seem to be able to turn your hand to anything and make a good job of it. :)
Dash is very cool for a try it..Quote:
Trim it, flock it and fit it.
Its all loose end bits now really i have some quite expensive purchases infront of me including FG bonnet and boot, inlet manifold (an sbd only item), corsa B bias pedal box, rear coilovers, exhaust and a host of fixtures fittings switches etc etc i have a few other little bits to sort out before i can fit the engine including the gear shift, rear arches and some all over painting.Quote:
Originally Posted by Jay
The engine is sitting fully built on the stand with the posibility of a replacement oil pump for piece of mind being the only work i may do to it so it wouldn't take long once everything is in place (rack etc) then its just a case of putting parts back on so i'm still aiming for may to be near completion but realisticly i want it done for PV.
+1. All round skills! Loving it!Quote:
Originally Posted by Nick J
Ernie, Nick, Benn and Pete thanks and Ernie were the funk did you get 4 bright green blobs from? Have you been liking trackdays @rse again???
boy got skills indeed :thumb: And likely count, olly is brilliant for rep, I keep getting it randomly from him... I got repped for a post that said "Edit, just seen other thread." the other day lol
Well when needs must lol.Quote:
I think its from selling lots of stuff.
Any time dude, credit where credits due.
Evening every one i thought as i hadn't updated this for a bit (mainly due to other commitments that get in my funking way) i thought i'd let you lot in on what i have done.
Off the back of the quote above i decided to tie the rear end in with the fronts new found wideness by adding some width across the rear axle also.Quote:
First of all i was going to use some TAS widening spacers i came across (pictured below) but i have since changed my mind in favour of something of my own design. My design is of a similar weight but considerably stronger than just bolting a solid block of metal between the axle and hub.
http://i248.photobucket.com/albums/g...earaxle016.jpg
And here is my attempt at a wide rear end....
http://i248.photobucket.com/albums/g...earaxle006.jpg
http://i248.photobucket.com/albums/g...earaxle008.jpg
I cut the original hub mounting face off the axle (it came of reasonably easily) as you would when doing a rear disc conversion plate.
The width was then achieved using two 50mm wide sections of 8mm thick walled box that i have welded between the axle and the old hub mounting face. The new found width was then braced and strengthened using some 50mm box section cut to a 90 degree angle and some 3mm walled tube.
http://i248.photobucket.com/albums/g...earaxle005.jpg
http://i248.photobucket.com/albums/g...earaxle003.jpg
http://i248.photobucket.com/albums/g...earaxle009.jpg
http://i248.photobucket.com/albums/g...earaxle010.jpg
http://i248.photobucket.com/albums/g...earaxle011.jpg
And against the TAS version
http://i248.photobucket.com/albums/g...earaxle013.jpg
After completing this i made up some strengthened suspension mounting points (as i'm going coilovers all the stress is now focused on this one mounting point instead of across the springs and shocks)
They are also made from box section with the top cut out then strengthened and spaced to accommodate the shock - there is a nut welded to the outside edge and the mounting point its self is now 15mm closer to the centre of the car to reduce the angle that the coilovers sit at with the rear turrets were they are.
http://i248.photobucket.com/albums/g...earaxle012.jpg
http://i248.photobucket.com/albums/g...earaxle002.jpg
And i painted up my newly acquired bilstien rear shocks so decided to attach then for good measure
http://i248.photobucket.com/albums/g...earaxle017.jpg
http://i248.photobucket.com/albums/g...earaxle022.jpg
http://i248.photobucket.com/albums/g...earaxle021.jpg
Does anyone know anywhere that stocks shocks for these coilovers?
This week i might actually get some work on the car done lol
