that is sweeeeeeeeeeeeeeet!!!
Originally Posted by gary_808
No room to redill the ford hub. The grass track boys use tubes attached to trailing arms not double wishbone...
http://www.drdracing.co.uk/images/Rear%20Arm.JPG
With those rear arms you can either fit sierra setup or vaux.
Omega i trailing arm and very heavy! Also getting 5 stud hubs for mantastub axles is impossible and omega fronts won't work - I've got some in the shed and checked. They use a steering box so the arms are in the wrong place.Quote:
Originally Posted by Ben
Me too!! Will start to look like a car again then.Quote:
Originally Posted by t45_ste
:thumb:Quote:
Originally Posted by dontliftdrift
And before someone asks why not just use a trailing arm setup its because on compression the wheel move upwards and forwards much like a rear beam. I want double wishbone because it moves upwards and inwards. Firstly it creates some negative camber & secondly it will aid outside arch clearance which is tight!
i've seen some with double wishbone,
also seen a few off road buggies with double wishbone/seirra bearing unit and vauxhall wheels,
there are 100mm pcd seirra hubs out there, it's just finding them
those rear arms are from drd racing and they also make arms to take vauxhall drive shafts and hubs, i should know as i work for them :D try our website drdracing .co.uk and drop us an email if you have any questions or need any help
if you are on corsasport them check out phillip2 rear engined corsa project thread as we did the fabrication work on it
Very impressive progress dude,keep it up!
Originally Posted by lee_dodd
I've been on the site & seen the parts you offer, however the vaux fitment is still trailing arm like above & not double wishbone.
Originally Posted by andy_017
Cheers
Had any time on this lately mate? :)
Took the engine back out last nite. That is all lol
I'm waiting for the main part of the cage now, which I might order next month.
