I then carried on with the wiring in the engine bay. Switching it over the other side is turning out to be very easy! Everything basically needs to get shortened which is easy enough and means wires keep the same colours. The only thing I need to lengthen is the reverse switch (mentioned in previous posts), wire to indicator on pass wing, RHD headlight could do with an inch or so to rule out any potential problems and I want to put a switch in to overide the fan so need to run 2 wires back into the car.
Only got one pic then the battery ran out! lol
http://img.photobucket.com/albums/v3...8-01-09009.jpg
Questions if they can be answered here rather than posting a seperate thread...
- Does anyone have a rad temp switch plug (male part) they wouldn't mind parting with?
- I noticed the ignition wire that goes to the starter has a section soldered in that is quoted as being a resistor cable. Can someone explain why its there and does the resistance vary between engines ie do I need to change it with going from a 1.0 to a 2.0?
- Starter end, where the above resistor cable goes back into a normal black igntion wire, there's another igntion wire coming off with a single connector on the end. I have a feeling it originally went to the coil - can i get rid of this? I take it, it can't be used as a spare ignition feed because the resistor cable inline effects it?
Thanks for reading.
