video 1 : http://www.facebook.com/v/10150171333002997
I trap 113 and no n2o just 204 at the wheelsQuote:
Originally Posted by bodleyhenley
Assume XE Nova's are a bit lighter? Is yours stripped out?
Maybe mine's only making 204bhp / standard power then, maximum I ever trapped was 108.92mph...
Hmmmm :(
13.5Quote:
Mine is a wheel figure so flywheel is 240.2 according to the rollers but thats a calculated figure and both figures will vary between rollers! I have seen mine at 280 before but its not believable!!
My mk1 MR2 turbo ran 13.4 @ 100 mph with 280bhp so no idea how some of these times make sense but they are obviously right. That was a 2.0 60ft time!
Obviously weight comes into it somewhere but a really rusty mk1 MR2 isn't that heavy!
Lee tbh i think luck and maybe a tail wind was on my side that day as all other runs were 13.7 13.8s around 101-103mph
And as i posted on my wip i whent last weekend an there was 12-15mph head winds, so my bests were 14.0 @ 99.9mph
But least they were cositant an all other guys run times were down by around or more the hath a second too, so not just me.
I raced an Mr2 turbo rev3 at york, it was very nice and had a big front mount intercooler.
He did a best of 13.0 @ 107. something .... I asked him about the power and he said about 280ish, I think he was running more like 320bhp I don't think he had a clue as he had just bought it! I was only just reeling him in when I got grip.
My old mr2 turbo rev2 with about 225 (standard ish) did 14.3 @ 95mph
Originally Posted by Lee H
RE: headwinds, interesting point... There was a pretty strong headwind blowing about 15/20 degrees off the runway centreline (20mph I woud say as it was freezing!). Possibly makes a difference with a brick shaped nova. ?
I know I got 104.5mph at the beginning of the day, and I think the wind was stronger then. Towards the end of the day the wind dies down... then I was trapping 107/108.
i managed a 14.92 on a c20xe nova standard tyre pressure on budgets full trim at york at 90.8 mph, not the most impressive time but it held its own against other cars in its class
yeah i noticed the 15/20 mph head wind at york too, it slowed our N/A time down by .2 but we still managed to run a 12.4 with only a 50 shot of gas so i'm guessing that would work out at 12.2 if the head wind wasn't there.
David.
Car-C16xe Nova saloon: 125-130bhp
Tyres-proxies r888-185/60/14
Estimated car weight-Around 680kg- Stripped interior
Time-14.90 @93.0mph
Reaction-0.855
Run at-Santa Pod Fast Show 2011
on the last run i did i ran 14.91 @93.9mph and missed third gear so was gutted as could have been 14.7 or 6? :(
Car-Honda Civic Type R
Tyres-215/40 R17 Nankang ditchfinders
Estimated car weight-1270kg, full road trim
Time-14.03 @ 102mph
Reaction-1.476
Run at-York Raceway 29/5/11
Car-Vauxhall nova c25xe
Tyres-195/50/15 Firestones
Estimated car weight-950kg? stripped rear
Time-14.2932 @ 98.84mph
Reaction-. 5044
Run at-Santa Pod retro show 2011
X16xe nova R6 carbs 113bhp (@ wheels)
Toyo proxe 185 50 14
850Kg? (stripped but full tank of fuel)
15.0522 @ 90.69mph
Santa Pod
Car-C20 LET Nova
Tyres-Worn Yoko's
Estimated car weight-750Kg
Time-13.27 @ 108.98MPH
Reaction-.5750
Run at-Santa Pod - 7 August 2011
Not bad for my first 1/4 mile on some nearly shagged tyres
Yeh, 108mph terminal is 12s if you can hook up well. I ran a 12.8@109 a few years back. And im useless at launching lol
Yeah i reckon it will no problems, ive not had her out much so still getting used to it, the tires where fairly worn and only road going tires. Im going to stick some R888's on her just trying to find some wheels that will fit over the calipers! as the 16's catch ever so slightly so can only imagine it being worse with the chunky tires.
It never once scraped when i had it with the yokos, i do remember Darren put those tyres on then it started to catch front wings, i personally would have changed those tyres and put on a more suitable tyre, failing that raised the front slightly. i also used to run Uniballs intead of ball joints, dont no what happened to those, also a sytec cleanable fuel lilter?
Might see you at the pod next year be nice to see it going up the strip again, but hopefully i will be in a car capable of 9.5s.
Oh will get those gears sent when i get a min.
It actually scrapes on the rear under hard cornering i think i may have a play with the suspension and stiffen the rear up a bit, they may have softned and could possibly need a refurb as i suppose they have been on the car a while.
Stu i keep meaning to come and see you, i havent fitted the wideband yet, need to weld a boss a bit further down the pipe for the lamda and then ill pop over. I am thinking about taking it to track and road but not sure if there will be any point without mappable management?
and yes its on ball joints now dont know why anyone would of changed those? the fuel filter was relocated when Darren fitted a new fuel pump I belive (see pic)
http://i52.tinypic.com/mcyomt.jpg
Same place fella :thumb: Bullet filter still there aswell, it can be dismantled and cleaned, in the box of reciepts there should be 2 dowels that slide in the fiter holes on the opening end, a screwdriver or equivalent can be used to screw open using the dowels, propably never been done in around 5 yrs:confused:
Car- c25xe belmont
Tyres- toyo t1r
Estimated car weight-`1000kg?
Time- 14.11 @ 102.3MPH
Reaction-.6960
Run at- york raceway 29/08/11
how do u put photos on hear
http://blogs.sundaymercury.net/weird...ar-closeup.jpg
you need 15 posts which arent spam
Car- Nova SX Td
Tyres- Yoko Spec 2
Estimated car weight-`9000kg?
Time- 16.48 @ 80.66MPH
Reaction-.6797
Run at- Santa Pod Raceway 21/08/11
Car - Vauxhall Nova c25xe standard bar stainless magnex system and cone filter
Tyres - R888s
Estimated Car weight - 900ish? stripped out bar dash and drivers seat
Run at - Shakespeare County raceway 02/10/11
Reaction - 0.270
60ft-2.208
330ft - 6.033
660ft - 9.096
MPH1 - 80.85
990ft - 11.615
1320ft - 13.847
MPH2 - 104.91
TIME - 13.847 :d
Car- Astra MK4 1.8 16v
Tyres- Toyo R888's 14psi
Estimated car weight- 1550KG
Time- 16.663
TM Speed- 81.52
Reaction- 0.424
Run at- Shakespeare County raceway 2/10/11
Car- mk 2 c20let nova standerd bar 3 inch regal downpipe to side exit exhaust
Tyres- kumho road tyres (psi 16)
Estimated car weight- 950kg (just a estimate got full interior 16 inch rims etc)
TM Speed- 109.12
Reaction- 0.604
TIME-13.805
Tyres - Yokohama Parada spec 2 195.50.15
Run at - Shakespeare County raceway 16/10/11
Reaction - 0.255
60ft-2.022
330ft - 5.591
660ft - 8.504
MPH1 - 84.55
990ft - 10.934
1320ft - 13.106
MPH2 - 106.74
TIME - 13.106 :d
TM Speed- 107.11
Reaction- 0.404
TIME-13.396
Run at- Shakespeare County raceway 30/10/11
wtf^^^^^^^^^
whats these messages all about ^^^^^^^^^^^^^^
