Get some pics when its out the garage :)
LOL. Will do.
Bit more tinkering last night, followed by a full on tidy up in the garage.
Had to lengthen the AFM wiring, so soldering iron was out for that, cut a hole in firewall & routed the servo vacuum pipe work through, and investigated the clutch pedal spring issue I was having & got the pedal to sit lower (chuffed with that one).
I got the Mrs to help me with setting up the gear linkage again. She held the stick & I used the drill bit method as per Haynes manual, spot on result first time.
as i always do it that way , and always works first time , camt belive so many people still guess lol
good news on the progress aswell
I've always managed to do it without the drill bit in the past tbh.
glad to here your getting abit closer to having it all done, you have to get it done for the cornwall trip
Slowly but surely, small jobs are getting done.
I lowered it down off the axle stands once again & saw her sat on the new fr springs. (pics to come) Fairly low, may settle some more hopefully. I pushed the fr end out of the garage door way & set about drilling the hole through the bulkhead for the passenger side mounted bonnet release. All fitted & operational. (pics to follow)
Head unit is fitted & wired in with some RCA cables run to the rear should I wish to fit an amplifier.
Jobs for this week are earth cables at the various usual points, fit battery terminals etc to main power wire. See how much of rear brake pipes can be fitted which includes a lengthy run of braided aeroquip for the M/C to bias valve run.
've been blagged for some pics but what I've taken isnt much use tbh.
Quick shot of it poking its nose out into the sun.
http://i30.photobucket.com/albums/c3...i_build048.jpg
Pic showing L/hand mounted bonnet release cable.
http://i30.photobucket.com/albums/c3...i_build047.jpg
And the boot area cleared & hoovered of debris & awaiting my braided brake lines which will be here tomorrow.
http://i30.photobucket.com/albums/c3...i_build052.jpg
Plus whilst a bit bored on Friday evening, I took a pic with the stainless back box propped up under the car. Next major job is getting the zorst tweaked to line up with the manifold, hence brakes for towing.
http://i30.photobucket.com/albums/c3...i_build054.jpg
Hopefully more to report later in the week.
very nice mate
Thanks. Its been a long time coming. I'm like a claustrphobic mechanic, working in my single garage.
Getting there, getting there :)
Liking the zaust
Nice to see its getting there Craig! :thumb:
looks lovely craig :thumb:
very nice indeed! and in the boot is that a battery box?
Looks minted Craig
Should be good to see it done :)
Yay speedlines looking good!
cool pics, looking good
Yeah whats with the battery box mate? you running one in there?
All looks to be getting there though mate.
Corsa Servo IIRCQuote:
Ahh lol Makes sense! :roll:Quote:
Originally Posted by SRimon
Cheers all. Just niggly odds & ends to sort now.
Hopefully running by sometime next week.
Looking good craig, you missed a bit under the washer bottlelol .
Lend me some of your enthusiasm Craig lol
Thats where the washer bottle was... battery was meant to go there but it was too close to the dispack & strut brace, so will have to tack the washer bracket back in I expect.Quote:
Originally Posted by Jeff16v
Where do I send it? Paypal? :cool:Quote:
Originally Posted by Mike
looking good mate!! i love your exhaust!! the front end looks well mint.
keep it up:thumb:
Thanks Mike. Love your Avatar.
Heres the beauties I collected this morning, will be racing home to fit them like a school kid on his birthday!
http://i30.photobucket.com/albums/c3.../braided02.jpg
http://i30.photobucket.com/albums/c3.../braided01.jpg
Full front/Master cyl to rear braided lines.
That explains it:thumb:Quote:
Those braided lines are yummy, expensive?
The braided brake lines werent too expensive actually. I had them made up by 'exact'. Think the guy used to work for Goodridge down here in Exeter.
My local rally supplier ordered them in. Full set of flexi's for the beam & calipers was £39. Just paid £40 for these 2. One is 3 metres long & the other 75cm. Not bad IMO.
Heres the progress of starting to fit them up.
Master cylinder end.
http://i30.photobucket.com/albums/c3...s/dscn2356.jpg
P-clipped down to boot floor, though its covered over.
http://i30.photobucket.com/albums/c3...s/DSCN2358.jpg
From a T-piece, copper brake pipe runs out to the flexi's under the boot floor.
http://i30.photobucket.com/albums/c3...s/dscn2357.jpg
Tonights plans are to screw more P-clips in & tuck the bias valve away on the A-pillar. (camera ran out of memory for the valve)
Im liking the lines :)
good work CG, kinda like the stealth performance thing going on - Hidden internal brake lines, etc. Very tidy ;)
i would have thought you'd put a gromit in the engine bay where the braided line passes through...
Cheers, that is kinda what I've always wanted to achieve. Even back when the turbo was running, no external signs of what lies within.Quote:
Originally Posted by Ash
I meant to have something on there, but my box of assorted grommets failed me. I will address it. Maybe find the OE one in the shed one day. There are a couple wires to run through that hole aswell, so will seal it up when I'm finished on the PAS wiring.Quote:
I just bought myself a pipe flaring tool for the brake lines..... report with pics & mucho swearing tomorrow.
Dont i have to re do mine soon.
Which tool have you bought Craig?
I got a Silverline flaring kit from Tool station. £10.18 with lifetime guarantee.
1st attempt at a flare was successfull & I proceeded to install 1 line before being bored & calling it a night.
Motivation has fallen away again. damn!
get crackin' craig.. will be soon done..
get it done cg.....or if still cant be botherd can come out mine and help me tidy all my wiring up, is a right mess :(
LOL. I'm no wiring man Spud.
Hopefully get out in the garage after tea, unless the GF has other ideas.
FFS Craig, crack on with it :p lol
PV's like 4weeks away!
