At the min, its got apex springs (40mm) allround.
Apex shocks on the front and billstein shocks on the rear.
It looks real low at the back because its got a load a sh!t in the back of the car.
Cheers burgo, I bought them off ernie for £50, I gave them a quick style refurb whilst I was working as a tyre fitter and luckly one of the chaps we did alot of work for decided to spray them up for me for free! Bonus!Quote:
wheels look the tits
http://i25.photobucket.com/albums/c5...h/DSC00273.jpg
The first time in a good few month that old Jeremy has moved.
http://i25.photobucket.com/albums/c5...h/DSC00274.jpg
We put the bonnet on and got abit closer to putting the clutch cable back in. The section that runs through the bulkhead needs a little bit more chopping and angling so it points in the right direction. Ive also sourced a GTE tank which I plan to pick up at the end of the month. I also need some brake pipe union nuts.
^woah doesnt look like theres alot of clearence in that shot coz I took it from a retarded angle.
Anyways.
Me and Jim-bob have been pottering about for the past week in preperation of my pay-day. I got some bits sorted and got some items I needed through the post.
Pay-day Wednesday!
I picked up the fueltank (cheers chimp) and my bits from vauxhall and plodded on. Its been 1 step forward, two steps back for a while now so I was determinded to get something done.
http://i25.photobucket.com/albums/c5...h/DSC00289.jpg
Jim-Bob came round to swap over his gearbox, so I thought Id take a photo.
Whilst Jim-bob changed his gearbox, I got on with some wiring.
Armed with the girl friends laptop and a pair of wire strippers I began. I was using the diagram from the articals section. I kinda started at the bottom, wiring the nova loom to the XE, ie the alternator and oil sensor.
I noticed that one of the sensor at the front for the sump had been damaged. The wires had pulled out of the terminals.
http://i25.photobucket.com/albums/c5...h/DSC00290.jpg
http://i25.photobucket.com/albums/c5...h/DSC00291.jpg
Jim-bob is gonna repair the sensor.
The next step was the fueltank. It already had a pump :thumb:
Unfortunatly I bought the wrong size fuel line so I need to get that sorted. Appart from that everything else was in place.
http://i25.photobucket.com/albums/c5...h/DSC00294.jpg
http://i25.photobucket.com/albums/c5...h/DSC00293.jpg
When we pulled that sensor out we thought the sump had been drained.
http://i25.photobucket.com/albums/c5...h/DSC00295.jpg
Whilst wiring up the ICV (idle control valve) I noticed on the same loom, there is a blue wire with a spade style conector, where does this go?
Cheers for looking
That would be for the water temp feed for the dials on the donor car. You dont use this, you shoud be using the one on the nova loom :)
Make sure you fit the alternator before you put the inlet on!
