Cheers Dude
er, pictures of tyres fitted? shame you can't even offer them up to the car lol
Update.
Stripped and cleaned up my front hubs and rack the other day.
Started with this.
https://fbcdn-sphotos-a.akamaihd.net...04172078_n.jpg
Started on the calipers first.
https://fbcdn-sphotos-a.akamaihd.net...91976781_n.jpg
Then the hubs.
https://fbcdn-sphotos-a.akamaihd.net...34485770_n.jpg
https://fbcdn-sphotos-a.akamaihd.net...36300880_n.jpg
and then the Bottom arms.
https://fbcdn-sphotos-a.akamaihd.net...29064905_n.jpg
https://fbcdn-sphotos-a.akamaihd.net...35115101_n.jpg
And after a good old grind and a wirewheel I painted everything in primer.
https://fbcdn-sphotos-a.akamaihd.net...17026786_n.jpg
It is grease on the hub btw.
https://fbcdn-sphotos-a.akamaihd.net...68451954_n.jpg
https://fbcdn-sphotos-a.akamaihd.net...99402168_n.jpg
I even did the hoses.
https://fbcdn-sphotos-a.akamaihd.net...35779222_n.jpg
https://fbcdn-sphotos-a.akamaihd.net...28077861_n.jpg
and here's the rack before and after..
https://fbcdn-sphotos-a.akamaihd.net...11857024_n.jpg
https://fbcdn-sphotos-a.akamaihd.net...38956280_n.jpg
https://fbcdn-sphotos-a.akamaihd.net...88707420_n.jpg
And finally the wheels.
looking good :thumb: what size are the tyres? same as mine?
Thanks, Yeah I think so, they are 185/60R14. They look bigger than I had hoped but I still think they will look great on a Slammed OE Nova with bump strips!
Stripped the engine tonight as I plan on changing all the gaskets set the valve clearances...
Here are a few pictures.
The head that appears to be in good condition :)
https://fbcdn-sphotos-a.akamaihd.net...75205822_n.jpg
Sump off.
https://fbcdn-sphotos-a.akamaihd.net...22358944_n.jpg
Injectors etc, I will be testing these at work tomorrow to :) Can any one spot the fault here?? Rep if you can.
https://fbcdn-sphotos-a.akamaihd.net...93214845_n.jpg
And finally the block. I need to get some solvent to clean everything off but overall I am happy with the condition of every.
https://fbcdn-sphotos-a.akamaihd.net...76471649_n.jpg
https://fbcdn-sphotos-a.akamaihd.net...09590375_n.jpg
i had a td sx, ;oved it to bits......till i got 3 points for over use of the wrong pedal!
got hit by an uninsured/moted/taxed/licenced ars@hole that was speeding through the village still miss it though!even though the accident the moved the engine showed up the fact that it was rotton!!
leak of pipe mate
unless you have a three cylinder engine???????????
