Love the filter Benn, any subtle changes this year?
awesome work, all in that teeney garage, heroic stuff.
Top draw as always dude :)
Cheers James, more when i get home.
Got the hub off, measured everything and worked out the angles again. Still says 2.9. So put everything back together and will wait till i get a tracking report before worrying any more. Adjusted the handbrake as well so it's just touching as it should be set. Did a lil touching up too.. As bit had got marked when fitting, so took finished pics.
http://img.photobucket.com/albums/v3...n/IMG_0684.jpg
http://img.photobucket.com/albums/v3...n/IMG_0685.jpg
Did the brake lines in blue to match the under side of the car (lines on the floor plan are black so they don't look like I've painted over them while doing the floor)
Saw this some where, thought what a great idea. So used some black silicone and did it. Looks tidier i find.
http://img.photobucket.com/albums/v3...n/IMG_0688.jpg
Awesome Benn, so lovely underneath. Although the fuel hose needs treating, it's got dust on it. :)
Overspray on wheels.
I used the rubber bits from a metal P clip for those lugs, worked well.
looking good ben :thumb:
real credit to you buddy
I like it mate, I actually thought about colour coding brake lines the other day when I was under the Nova. I'm convinced :)
Next time I'm under it's getting done. Not quite body colour but Gold Hammerite which is rather close.
All nice and pretty clean Benjamin. Top work.
Do it Tek.
Cheers Si, not quite in your group but i try.
Drove the car today, back end feels alot better and now so light feeling... Tracking tomoz.
Right back to the update...
Ordered these from Vauxhall as mine were melted while being powder coated. 42p each and still stocked.
http://img.photobucket.com/albums/v3...n/IMG_0689.jpg
http://img.photobucket.com/albums/v3...n/IMG_0690.jpg
Fitted, greased, cables on and adjusted (thanks Dan) hand brake now locks up on to clicks. Getting a lovely bedding in sound from the new shoes,discs,pads..
Moved the car out side, started first time, sounds great, no tapping. being that it hasn't been started since early Jan. Very dusty tho..
http://img.photobucket.com/albums/v3...n/IMG_0691.jpg
Then refitted the glove box back up from where we thought the alarm was going mental.. (it wasn't, was a dieing battery)
I fitted a new chromed door catch, after my old one was jamming, plus i had these chromed...
http://img.photobucket.com/albums/v3...n/IMG_0692.jpg
http://img.photobucket.com/albums/v3...n/IMG_0694.jpg
Chromed screws..
http://img.photobucket.com/albums/v3...n/IMG_0695.jpg
Catch fitted,
http://img.photobucket.com/albums/v3...n/IMG_0696.jpg
Door all built up and working smoothly....
Dan helped me fix a small fuel leek from the pump to filter. The braided hose just wouldn't seal. So changed it to a rubber one as a temp job.
Took the car for a test drive, front tracking must be out.. Rear isn't right, but the lightness on the rear end is now totally gone. which makes me very happy.
Using some straight we worked out (very easily) that the rear drivers wheel is very out of line...
Next day, off to get the tracking done... big thanks to Jim, Liam, Euan at Protyre.
On the ramp, trying to get the gauges on.. As it's low they have to mess about setting them at a different angle.
http://img.photobucket.com/albums/v3...IMG_0369-1.jpg
Cheeky underside shot..
http://img.photobucket.com/albums/v3...IMG_0370-1.jpg
Tracking/toe... Right out the other way front where it was.. Great! Euan, thinks it might have been old worn bushes, not un-even hubs..
Now it's got new bushes, the shims have pushed the toe out the other way... So strip the hubs off again, shims out, re test... Aaggghh.
may be a silly question but weres your rear towing eye benn??
That's weird, I thought the handbrake guides were white nylon,
How much was the chroming Benn as I have a bag full of bits to get done but am struggling to find anywhere
Nice ramps at the garage,
Look at the dust on the poor thing, lol
looks good albeit a bit dusty
Been removed, bumper to have cut out removed and smoothed.
I thought there where white too, but still plastic, but i dont know,
These are the cross over part number as they are the same on Corsa B and C's...
Chrome, well i had a load done last summer, just didnt get it all fitted. But hes very good on price, cheapest ive found and the work is perfect.
Oh yea its minging. :(
Have you had to space the front wheels out to stop them hitting
The f28 on full lock ?
Let me know how far you did if you did
lock stops i believe... as in hd jubilee clips on the rack
Yeah, next time you have your front arms off for re-painting/buffing or whatever just weld on some lock stops.
Where too tho? Nothing gets that close does it? I tend to stop steering with i hear tyre on arch.. lol
/\ thats exactly what's do at the minute but it makes a horrible noise haha
Might look into lock stops but as you said Benn nothing gets close enough to stop the rack unless you fit the stop under the rubber boot
Yep, that's where i lost interest... lol
Looking good mate, dusty but good lol. Iam going to see about getting a few bits for mine chromed this week as well hopefully .
Iain
Very nice Benn.......... I cant wait to see the particular part fitted that will make all the difference to the car this year. ;)
Nick.
Tracking checked again, this time its much better and good enough not to worry about. Very happy with that, so took it for a small test drive over the back roads... Back end now feels tight and much better. So much better than it did before.
On to the turbo swap.
Yip Yip Hooray!
Going for a K16 or a different one all together?
I have a rebuild and hybrid k16. Which will be nice.
/\ from where?
I was one that was rebuilt at your place, has done 1k but the owner has gone much bigger spec. So sold me it dirt cheap, and i mean DIRT cheap...
I was only curious were you got it as I didn't want you buying crap thats all :)
So the difference between standard K16 and Hybrid K16 is?
I have no clue.. Ment to make them better... James will know it all tho..
