Hi Keith,
It was an excellent weekend thanks, 3rd place on Saturday (with a new personal best time for this car), and then a 2nd place on Sunday, with another improvement on my PB.
There's a bit of a report at this link, and you can also access a PDF file with all the times on it if you are really bored!;
http://gurstondown.org/latest.htm
The Mini of Neal Masters that was always beating me last season was the one quicker than me again, he has a brand new KAD works engine for this season, with all steel bottom end and 9,200 rpm capability.
It's a monster, he's pulling out between 4 mph and 7mph on me at the 2 speed traps at Gurston.
I have a few more developments to implement before the next race, which I think will just about put me on equal terms with him.
I'm going to fit ARP rod bolts and whack the rev limiter up from the current 7,500 to 8,000.
That should allow me to hold onto 4th gear for long enough to avoid the 2 changes to 5th I was needing to make with the new Quaife gear cluster fitted.
I may also try and find a longer 4th gear ratio, but that could prove tricky as Quaife no longer make parts for the F10 'box.
Apart from that I was suffering a leaky brake bias valve (leaking from the unions), so I need to sort that out, and the new lightweight lithium race battery only held charge long enough for 2 race runs before it gave up!
