The battery is probably fooked, if the engine doesn't get run often....
Also, the twin fogs, do both your fog lamps worK? ;)
Not sure whether its a fail, but i asssume if two are fitted, then two have to work.
If you're swapping lights over anyway you may as well put standard ones on and know that you'll pass :S
Mine passed with 2 fog lights but they were both working, because there only supposed to have one they only need one working one as the reverse doesnt get checked
No reverse light is needed for uk roads/mot.
BUT if you have 2 fog lamps, and only one is working, that may be a fail imo...
As there are two fitted, even if only one is needed.....
Its the "if its not there it cant be tested" kind of rule.
checked up on the lights, if theres no reverse light it isnt tested, and by law only 1 fog has to work, even if theres 2 only 1 has to, so going to just put the fog light in and hope she passes, if not then its only a light swap, standard light, there and then, reverse bulb in, sorted
Aye, the reverse light is never tested :)
Even if fitted.
Id still just wack the standard cluster back in tbh, just to be sure.
i might do, thats it ive still got them lol
actually i have on the office roof with the twin reverse light lol
just bought an immobiliser kit off draper, should fit it enxt week or the week after :thumb:
euro lights back in and digi dash back to original mileage :thumb: tomorrow is fix seat and cv boot, pics 2tomorrow :thumb:
