great work here simps looks impressive. i spent hours last night reading this whole thread i had match sticks holding my eyes open as wanted to read it all must have crashed out last night so didnt reply.
cant wait to see this completed.
good luck.
good luck.
Originally Posted by Nova_Tek
Thats the key bit isn't it! lol
Originally Posted by 1.3sr_kane
Thanks for taking the time to read it. Its nice comments that give you that extra push to go down the workshop on a cold december evening! In some ways I wish I was married - I'd have more reasons go get down there out the way then! lol
Bellhousing ordered, should be here tomorrow. Shame I'm away this weekend to offer it up :(
well reading your thread has given me some more inspiration to complete / start the 3 nova's and the escort and finish my turbo golf.
lol
will be keeping a eye on your project to pick me up when i feel like cant be bothered to do mine
Had to head up the unit tonight because all tho it dosn't leak water up there for some reason the snow gets in everywhere so I had to cover the car up. Before I did tho I couldn't resist getting the grinder out again so I chopped out the last bit at the rear...
http://img.photobucket.com/albums/v3.../17-12-091.jpg
I then put on the bellhousing and slid in the torque tube. Just got to work out the best way to mount it all up and how now. The end plate on the tube is 10mm thick. I think I might get Shaun to make me up an ally plate that suits the contour of the bellhousing. I can then make a hole in the centre just enough the shaft to pass thru then I can drill & tap the plate for the holes for the slave cylinder to mount. I'll then have to grind off the welds on the torque tube end plate, slide it back, trim down the tube, weld it back up then bolt the lot together.
Anybody else got any other ideas?
http://img.photobucket.com/albums/v3...t/17-12-09.jpg
have i got much snow to look forward to at work tomorrow ??? x
simps, could you not, cut of the mounting plate on the torque tube, and make another steel plate, possibly the same thickness and make it to the same shape as the bell housing and weld it to the torque tube? seems a good idea :)
it would stress frqacture imop. id make a mini convertor plate to go between the bellhousing and torque tube. have you figured a clutch? is it a porker tube?
Originally Posted by bmw156
That is the other option, and probably the easiest. The plate is 10mm thick after all!
Originally Posted by Sloth
Its a 924 tube yeah. clutch is a normal XE one and going to convert to hydraulic
