Furthermore i had to add a small extra arm to convert the side movement of the shifter to a longitudinal movement
http://www.extreme-garage.ch/Blogpic...psnhatdyfh.jpg
http://www.extreme-garage.ch/Blogpic...psv8l9wjt7.jpg
Here's a video to show how it works.
https://www.youtube.com/watch?v=Sp5ZZYinRlQ
Another thing i've added was a new seperation between the passengers compartment and the new so called engine bay :)
For that i've built a simple frame
http://www.extreme-garage.ch/Blogpic...ps09etmjy6.jpg
and bolted some aluminium sheet to it
http://www.extreme-garage.ch/Blogpic...pswpt84uop.jpg
In the future this will be accompanied by a piece of acrylic glass to allow visibility to the rear
http://www.extreme-garage.ch/Blogpic...psbtfig77o.jpg
Thanks to the frame for the seperation i was also able to make the accelerator pedal work
The cable runs along the frame
http://www.extreme-garage.ch/Blogpic...psw189ij2m.jpg
trough the aluminium sheeting
http://www.extreme-garage.ch/Blogpic...psomdr1qpj.jpg
to the front where its connected to the original cable which, obviously, is connected to the loud pedal
http://www.extreme-garage.ch/Blogpic...psgukldv2a.jpg
Even more cooling related stuff had to done in the form of tubing therefore it was necessary to fabricate two holder
http://www.extreme-garage.ch/Blogpic...psahhegycl.jpg
they are now welded to the chassis and hold the tubes in place which run along where the exhaust used to be
http://www.extreme-garage.ch/Blogpic...pshuqofijw.jpg
