you have to reshell it !
reshell it you know it makes sense, id say your just being an attention seeker now lol 'ohh i dont know what to dooooo' :roll:
i ll take it off your hands and reshell it and have it back on the road this year.
.... just in time for the winter weather to maul it lolQuote:
Some serious misguidance going on in this thread...
Lets straighten some things out...
Yes and no.Quote:
Originally Posted by mowgli
Not quite.Quote:
It depends on how you wish to reshell it. It ok to keep the ID of the shell you want to keep/use. But you cant take the ID of the 'components' of a car, putting them in to a secondhand shell. You can only keep the registration that belong to those 'components' if you buy a brand new shell
Vehicles that have been rebuilt using a mix of new or used parts
In order to retain the original registration mark:
cars and car-derived vans must use:
The original unmodified chassis or unaltered bodyshell (i.e. body and chassis as one unit - monocoque); or a new chassis or monocoque bodyshell of the same specification as the original supported by evidence from the dealer or manufacturer (e.g. receipt).
And two other major components from the original vehicle - ie suspension (front & back); steering assembly; axles (both); transmission or engine.
If a second-hand chassis or monocoque bodyshell is used, the vehicle must pass a an enhanced single vehicle approval (ESVA) or single vehicle approval (SVA) test after which a "Q" prefix registration number will be allocated.
Originally Posted by Novasport
No percentages, its points and thats only true when the car is classified as 'radically altered', which in this case, would still end up in Q plate if a 2nd hand shell is used.
The registration of radically altered vehicles covers vehicles which are substantially altered from their original specification, but which are not kit conversions. In these cases the vehicle components used from the original vehicle will be given a numerical value in order to retain the original registration mark.
Allocating a vehicle registration mark
The vehicle must score eight or more points to retain the original registration mark. If less than eight points are scored or a second-hand or modified chassis or altered monocoque bodyshell is used, an enhanced single vehicle approval (ESVA), single vehicle approval (SVA) or motorcycle single vehicle approval (MSVA) certificate will be required to register the vehicle. A 'Q' prefix registration number will be allocated.
Scoring components:
The following values will be allocated to the major components used:
chassis or body shell (body and chassis as one unit - monocoque ie direct replacement from the manufacturer) (original or new) = 5 points
suspension = 2 points
axles = 2 points
transmission = 2 points
steering assembly = 2 points
engine = 1 point
Where there is evidence that two vehicles have been welded together to form one (ie 'cut and shut') a 'Q' mark will be allocated. ESVA, SVA or MSVA will be required.
DVLA are still issuing Q plates when age cannnot be determined.Quote:
Originally Posted by Ben
oOoOoooooOOOOOOoo check you out lolQuote:
Originally Posted by loggyboy
:eek: :eek: oh no... what a terrible thing to do, make an informed post with acurate information with back up quotes from the source... shock horror, check me out indeed. :roll:Quote:
Originally Posted by gunny
All those regulations are no use for me, as I'm living in Luxembourg :roll::roll: lollol
But I checked the shell, it's worse in the pics than in real. The front is good, no major rust, not even in the battery tray. And only 2 little holes in the trunk.
Ok, the floor has a few holes, but no major ones, most of the rust is surface rust.
For the sills, the outer sill is gone on the left side and needs replacement on the right side, but both inner sills are not rusty.
And the amount of time going in a reshell is the same as restoring this shell, imo.
And the next point is that the inner wings in the rear are so well done in fibre that I will destroy them when taking the rear parts of.
Means: I will certainly put it in storage, finish the other projects and restore it back to original condition
For some people, this may sound insane, but for those who know how to handle a welder, it sounds the best solution lollol
Yeah i realised all the reg rubbish was irrelevant to you!
Good luck with though! Look forward to seeing it when you dig it out!
youre the man:thumb:Quote:
Originally Posted by duick
and if youre bored... theres a complete irmscher sprint kit for sale here in holland
