F28 To ZLET
As above.
a mates fitting a Zlet to his corsa b, and was sold a F25 and was told it was a f28 6speed(he never thought to check) anyway he was told a f28 wont fit the Z with out a special conversion kit?
True o rfalse?
wil it be a a straight fit?:thumb:
people use the z20let bottom ends on some c20lets so my guess is it should fit. The kit will be down to the different mounts it will use an not the bolt pattern on the block.
Agree. For example to change a mk4 GSi to an F28 6sp will likely require special mounts. I expect the flywheel & clutch will all fit in the F28 bellhousing easily enough. Good opportunity to use a lighter flywheel & clutch combo.
