Can anyone tell me the BHP and Tourqe output of the Izuzu 1.5 TD engine pls
From Corsasport.co.uk -
Diesel specs for engines fitted in Vauxhall Corsa/Astra/Cavalier
POWER
1.5D - 49bhp 90Nm torque (isuzu)
1.5DT - 66bhp 132Nm torque (isuzu)
1.6D - 54bhp 96Nm torque
1.6DA - 54bhp 95Nm torque
1.7D - 57bhp 105Nm torque
1.7DR - 60bhp 105Nm torque
1.7DTL - 67bhp 132 Nm torque (intercooler)
1.7DT - 82bhp 124Lbs torque (isuzu)(intercooler)
ISUZU INFO
1.5D
Bore = 76mm
Stroke = 82mm
Idle speed = 830 - 930 rpm
Max revs = 5800 rpm
pump timing = 0.85 - 0.95
compression ratio = 23:1
Capacity = 1488cc
Injectors = 2 jet Pintaux, ID NP-DN OPD N 108
1.5TD
Bore = 76mm
Stroke = 82mm
Max revs = 5600 rpm
pump timing = 0.63 - 0.73
compression ratio = 22:1
Capacity = 1488cc
1.7TD
Bore = 79mm
Stroke = 86mm
Idle speed = 780 - 880 rpm
Max revs = 5100 - 5300 rpm
pump timing = 0.50 - 0.60 mm
Capacity = 1686cc
Injectors = 2 jet Pintaux, ID NP-DN OPD N 122
Submitted by duck
i think iv done rather well lolQuote:
Originally Posted by mark_mcd
cool cheers lads
Actually while we speak about outputs what can you expect from a boost/fuel tweak and induction kit?
