well there gte 22 spline ones i stripped them down today gave them a lick of paint then looked and thought **** does it matter which end the outers and inners go on help appreciated cheers:thumb:
naw i wouldnt have thought so they should be the same the only difference is the c.v. joints
up we go for some help please
If both ends are 22spline i doubt it will make a different.
The longer one... the weight in the middle goes closeset to gearbox. If you can work that out, you can match the groove on the shorter side. There is a minor difference.
cheers peeps
Will only go on one way as the outer end has 28 splines.
:thumb:Quote:
Originally Posted by Lee H
gold star for lee:)
I'm such a geek :O
on novas one side is 28 spline an the other 22 spline like said but on a corsa both are 22 spline an it does matter on them which way round they go as the inner cv slides up an down the shaft while the outer doesnt.
