Cant connect to Dta Ecu???!!!
rigged up a cable in work today and bought a usb to serial adaptor for my laptop,
set the laptop up to connect to the ecu through com 4 but it just keeps saying ecu not connected or turned off?
tryin to find out the fault with the car as it wont start when the ignition is on, the fuel pump doesnt kick in.
Im on the verge of breaking the car into bits and selling it!
pls help
cheers
Re: Cant connect to Dta Ecu???!!!
pls help
cheers
Well com 4 wont work because your using th USB port!
I take it you installed the drivers for the USB / Serial adaptor? You WILL need the drivers. Once you have them istalled, the usb port should automatically pick up the ECU when you switch the ignition on.
