i am getting a c14nz bottom end can i use the f10(4 spd 1ltr gear box)box on that engine? :?
if so do i used the 1ltr fly wheel or the 1.4 flywheel??
ne help will b much appriciated
cheers
shaun :)
cheers
shaun :)
i think you be alright as they share the same flywheel but i may be wrong!
u cant fit a 1.0 F10 onto a 1.2 or 1.4 engine - the 1.0 gearboxes uses different mounting points as the 1.0 block has a different casting
the C14nz block is the same as the 14nv block however which is the engine used in the nova sr
if u get yourself a nice 5speed box from an SR along with the SR top end (ie head inlet and zorst manifolds and cam) u have yourself an SR engine ;)
head and cam are the same on all the 8V 1.4's (except the sri's)
so the cam in the 1.4spi is the same as the cam in the 1.4sr?
