Hi,
After a cheap coolant pipe to send to a fabricator for dimensions to make a custom stainless one. Doesn?t need to be perfect as I?m not planning to use it on the car but good enough to get accurate measurements off!!. This is the curved pipe that runs after the lower rubber rad hose to the rear rubber hose to the water pump with the outlet to the matrix and inlet from the header tank.
Thanks
