C16XE sensors / Injectors
Hi guys,
Could someone please tell me what size the thread is for the standard coolant temp sensor in the C16XE engine.
Also looking to find out the standard crank trigger wheel pattern as the engine is not currently in my possession else I would check this myself. (is this the same across all of the XE engines?
Lastly, I am planning to run injectors from a C20XE, but am struggling to find out the resistance of these, or if they are high or low impedance.
Im not sure which would be best for what I need either the cream or blue, the engine is being built to run approximately 200bhp, any advice would be much appreciated.
Im going to be running an OMEX ecu on my setup and will be running all new sensors, so just need some information to get the correct sensors to match the ECU.
Many thanks,
Chris.
