e16se crank gear
my engine was stripped awhile back and the crank gear was broken off and thrown i have recently had the engine rebuilt i bought a genuine crank gear for a e16se but it doesn't fit the crank the gear i've got has got the woodruff key in the gear but i need a different gear because the woodruff key is built into the crank has anyone got any idea what gear i would need thanks
knock the key out of the gear?
any chance you could post up a pic
You have the wrong type. there are several combinations. sq teeth, round teeth, female key, male key. across the family of engines. its easy to get the wrong one. The key is machined into the crank so you cant knock it out. get the correct pulley
where from though i just took the part number from the e16se how would i find the correct one thanks
take it back, tell them its wrong and ask them for the right part?
i got it online i just matched the genuine part number ill have to go into vauxhall see what they can do for me
Thats the best way. take the old one with you and match it on EPC.
