C20xe engine with good spec
I recently just bought some new parts so am building a new engine so my old one is up for grabs
It is C20XE
Start from bottom up:
Early light weight crank
Light weight fly wheel
4 paddle clutch with new cover
New ACL duraglide bearings
Oil pump with uprated metal gears
H section steel rods
ARP rod bolts
Accralite 87.5mm high comp pistons (12.0:1)
Cometic MLS head gasket
Freshly built head
Newman phase 5 cams (with dizzy drive) from blanks
Double valve springs
Solid lifters and shims
Vernier pullys (early type belt)
This is majority of my old setup excluding my big balve head which saw 230-240bhp at the fly wheel! so I would estimate this to make 200ish!
There is a biuld thread of mine on here that will show most of the parts and vids of it all together in my car.... Please do not think by buying this setup you will also run 12.5 1/4's as its not my entire car setup your buying!
Price £2250 ono
