Ive been told I need to set engine to TDC on pot 1.
Then off wheel up, and put 90degrees before the crank sensor, however, to me that means its either 90 degrees seeing into the future, or 270 degrees behine?
Educate me lol
Educate me lol
lol ok heres how you do it
set the engine to tdc i.e. piston number 1 at full stretch lol
mount the crank sensor where it will be
put the trigger wheel on with the missing tooth directly on the sensor
turn the trigger wheel (not the crank) 9 teeth clockwise
this isnt the best of pictures as i turn the pulley the wrong way
i turned it anti clockwise isntead of clockwise
http://i228.photobucket.com/albums/e...e87/pulley.jpg
the missing tooth would be at the bottom of the picture when set up correctly
it would run correctly set up like my pic as its wasted spark
also ignore my flimsy crank sensor bracket
Here you go Matt, this should also be of some use CLICKYME
Thanks guys xxx
