hi i am thinking about puting bike carbs on a nova gte as are cheaper then twin 40s what would i need and best place to get the parts thanks dan
Have a search around it's been covered quite a bit, also pm Tom Reid ;)
Tom I want commission and not in kind lol
You'll get your just rewards in heaven, or at a show, if I see you first:wisewood:
You need the following
R1 carbs
Inlet manifold
modified alt brkt
move temp sender
MegaJolt, Edis and crank sensor from a 4cyl Ford
Trigger wheel
Make a crank sensor mounting brkt
Fleurolined hose, 44mm id, approx 16 inches required
Hose clips for above
Think thats it
Forgot to mention fuel pressure regulator and pump
Prey, you'll get whatever is put in front of you, more than likely a Scottish saugagelol
Check out my build thread for a gte engine on bike carbs and megajopt - done by tom reid.
I also want a commission....
...or a kfc.
thanks sounds like going to cost a lot of money?
Cost is relative, even forty's will cost a few quid, it helps if you can do the fitting/fabbing yourself.
