as above.. what box and shafts etc do i use?
cheers :)
cheers :)
f16/18 box and big block conversion shafts and hubs
so will 22 spline shafts and cav mk2 1.6 inners work then? like on the redtop conversion?
yep.Quote:
Originally Posted by novaboz
when i did mine i used 1.5 flywheel clutch and standard corsa d box ,fitted a good clutch and never slipped once cant remember gearbox code but standard corsa diesel,use the corsa 1.7 or combo offside engine mount as these differ as they are the 3 bolt one as opposed to 2 bolt
if its already a 1.5d your laughing as you can interchange most stuff and get the offside mount from a combo,there is a lug on the back of the block needs grinding off as it will foul the gear linkage
