big box of bits.... have a look pvs del possible
right, had a clear out, i have a big box of random bits. all are £10 ono!
can bring to pvs or will post for extra.
x4 arb mounts, with good cond rubbers
corsa type 2 chassis leg mount, could also be used for f28 nova leg mount with a little work
std nova rear mount
2.0 8v icv pipe, the one with a 90 deg bend
2.0 8v dipstick / breather tube
90 deg boost pipe, silicone, 2 inch bore
boost pipe off a frontera, hard bit and rubber bit, runs from ic to inlet, 2 inch bore
2.0 8v stat to t/b pipes x2
x20xev/c18xe crank sensor, works fine
jaguar xj6 clocks, veglia make, temp, fuel guage, battery volts, rev counter, speedo, with wiring connectors (price is for all guages)
x2 large intercoolers, perfect for let motors, from volvo 740's huuuge size.
ported sub box, for x2 12 inch subs, carpeted.
mk1 dash, bare ideal for drag car, inc glovebox
mk1 underdash shelf, NOT BROKEN!!!!
i may also have some other stuff. i will bring it all with me to pvs, and just let it all go there.
