going from t40's to injection help
right o folks as some of you are aware i have a gsi engine running on 40's however theyre not jetted correctly, i have the inlet ecu and loom from the gsi engine and i think ive got the dizzy somewhere - however when fitting the 40's the egr hole was blocked up. im running a facet redtop pump and regulator will this pump be enough? - what will i need to get the injection running ? or is it a case of bolt on wire up and away i go?
any advice on the wiring will be much appreciated
oh the car was originally a 1200 carb:thumb:
Phil
(before you ask why - i just want to drive my car as im a little skint at the moment and need to spend monies elswhere)
