The 'unlock' button on my Corsa key has finally given up the ghost today and unlocking doors and boot manually is a pain. Is there any cheapish way or repairing or replacing the key?
Cheers
Cheers
Might be able to strip it down and swap the button from a working key, no coding then.
Might be worth a try but looks damaged so not sure if would work. Will try get hold of a cheap key and give it a go if no other suggestions come up
Could get an opcom from eBay and do the code swap that way
Ok thanks
How about something like this? http://m.ebay.co.uk/itm/Vauxhall-Ope...200?nav=SEARCH
That looks promising, cheers
They usually have a issue were the button comes away from the circuit board and is a solder job done a few myself for people
If the mirror switch has fallen off the board then hop is lost for that key, it's broken unless you want to solder a new one on and fit a new case. If not go to vaux and get a new fob, and if your local I'll code.it with tech 2 if you want, take like 5 mins
