Amp/sub cutting out/interference
Hi, I have a few issues with my stereo. I have a Kenwood head unit powering standard front speakers directly and an amp powering a pair of 6x9's and a sub (through different channels).
1, I have had to turn the gain right down on the amp and turn everything on the head unit up, otherwise when I play music loud the amp cuts out untill I cycle power to it.
2, Sometimes i get a sort of whistling interference that varies with the speed of the engine. This normally happens when I first get in the car in the morning or last thing at night, almost seems as if it's when the battery isn't at its strongest. (All my phono leads are run down the opposite side of the car to power leads etc)
3, My sub doesn't start working untill I turn the volume right up then it suddenly kicks in but my 6x9's which run off the same amp work fine.
Any ideas?
Thanks in advance!
