Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: rwd nova
    small block power!!
    Feb 2007
    southport
    1,715
    Default rwd nova
    anyone know if this had been doen with the engine in the front? dying to finally do one ready for pv09, seeing all the novas at pv this year has inspired me.
    if so what rear axle and running gear is used?
    was thinking of a chavvette rear axle, carleton box and an xe in the front? any ideas?
    Aug 2006
    I live inside your pants
    4,527
    using a rear axel is the most difficult way to do it without space-framing the whole car, the floor will need to be ripped up to clear the propshaft and the buckhead moved to let the engine sit longditudinaly and there is very little 'solid structure' to mount the axel to once you've removed all the material necessary to get clearance.
    better to use a front cut of one into the rear of another, giving you rear/mid engined RWD. but linkages for gears are a nightmare. also considerations for the loss of weight from the front, cooling lines and front suspension must be made.
    better to just leave the nova the way it was designed and not violate two good novas to fulfill a sick fantasy
    Senior User Mike's Avatar
    Mar 2004
    26,594
    Yep, Austin done it some time ago
    As for space framing the front, ill show thee -
    4th year Membership Scab Club Member Dod's Avatar
    Sep 2004
    Co.Donegal ROI Currently: has no Novas...
    10,651
    Theres a twin engined Nova for sale in the Classified section, seemingly the rear engine started and drove but as the clutch cable was removed for modification, it doesnt drive now.
    Ideally, you could make up some form of Hydrollic Clutch (Most Ecowreaks running an F18 Gear box have this set up anyway) and as Merit Lover saud, cut the front of 1 car and fit it to the rear of another one. Its a big job, and you need to be well up on your welding before you could attempt it.
    I spent 90% of my money on Drink and Women, the rest I just wasted.
    small block power!!
    Feb 2007
    southport
    1,715
    i did welding at college and now do it at work so thats not a problem.
    does anyone know what raer axle he used up there?? ^^^^^
    Senior User mowgli's Avatar
    Apr 2002
    35,194
    as I have stated thousands of times, the track & wheelbase of a nova is the same as a std mk2 escort............
    small block power!!
    Feb 2007
    southport
    1,715
    Quote Originally Posted by mowgli
    haaha didnt know that, not cheap though.
    Apr 2002
    35,194
    capri axles are the same, & mk2 4 door rotboxes are still cheap.....
    the main problem with doing a rwd hatch is the lack of rear end weight..
    the mid engined concept is quite good, but is noisy & cramped & has more than enough problems.
    I have always pondered whether or not the carlton/senator/omega irs would fit if narrowed. the 2.0 16v omega would probably make a really good donor
    Jan 2006
    Somewhere in Kent Drives: 1984' 1.3 Nova Saloon
    4,736
    This was asked on migweb a while back, there was a yellow rwd nova ebay which I was watching, think he wanted about £7k for it.
    As mowgli says, mk2 escorts are useful: Rwd Nova
  10. #10
    Sep 2004
    10,651
    Irs worth a shot I reckon, look in the Projects Forum as theres a few been done there.
