Go Back   Performance Nova Group - PNG > General > Projects
User Name
Password
Reply
Thread Tools Search this Thread
Old 10-01-08, 06:43 PM   #1
djshaggeh
djshaggeh is a splendid one to beholddjshaggeh is a splendid one to beholddjshaggeh is a splendid one to beholddjshaggeh is a splendid one to beholddjshaggeh is a splendid one to beholddjshaggeh is a splendid one to beholddjshaggeh is a splendid one to behold
Default Project Jeremy
Well here goes..
Base Model a few weeks after i got it:
Genuine miles.
Until just before christmas I when bought I bought a set of cav GSI rims (cheers ernie ) had them refurbed and sprayed and got rid of the lovely sidestrips:
I was working as a tyre fitter before christmas and unfortantly i dropped my keys in a customers car and the *******s never came back. With it being a nova I only had one key. Silly me didnt check here to know that there is a code on the bottom of the ignition barrel thier. So i wired in a hidden switch, key, and push start, all maplins specials.
My dodgey wiring caused the interior and engine bay fan not to work, resulting in a very unreliable ride. So over christmas whilst having to drive my sisters superfly ka i decided its time to get this out my mates garden and put it to use:
As you can see from the sunshine, I bought the calibra donor car in the summer, my mate stripped it of its xe and weighed in the calibra. The engine has sat in his garden since...
Over christmas I landed a new job at a local parts place (allparts - http://www.allparts-automotive.co.uk) perfect! So began buying some tools and booked the 2nd week off in January. I had never had the guts to do this and had always planned to pay someone to do this for me. But after alot of research on this forums I thought "I can do that" and so:
and its out... (if it was only it was as quick and easy as writing this post)
But on a serious note, i dont have alot of tools (breaker bar, hammer, sockets 10-20 and a 30, spanner set, screwdrivers and two trolley jacks) and I managed quite easy. With some help from some friends of course!
Next step: strip out the sound deadening and nitromorez the areas i need to weld. Tommorow or Saturday - keep you all posted.
Taking an Engine out Guide (for those that dont know how to do it, like me up until a couple of hours ago)
Disconnect everything from the engine cable and pipe wise, always good to start with battery (label it if you want)
Radiator out, manifold out, hubs off (I disconnected everything and pulled the hub/driveshaft out from the gearbox as one piece, on both sides)
Take off the anti-roll bar, lower arms and the funky sway bar things on each side.
Disconnect the gearbox linkage by taking out the 'T' style pin, (you'll know what i mean when you see it) undo the bolt that pinches in the arm, get in the car n give the gearstick a wiggle.
Make sure everything is as clear as possible in the engine bay, wires, pipes etc.
Take the weight of the engine with two trolley jacks, one under the gearbox and one under the sump, on the flat bit on the left, use a square of wood. (not recommended: jacking on the sump, however mine was fine)
Undo gearbox mount first (right at the back, under the inlet right at the bottom, tackle it from drivers side front wheelarch) then the left hand side mount and finally the right. Obviously becareful with the last mount as the engine could tip, however mine didnt.
Slowly lower the engine onto three bricks (works well) you might have to lift the front of the car (two man job) and adjust it so the engine is NOT supported in anyway by the car.
Get a couple of mates to either:
Lift the front the car up and roll the car back over the engine or as I did (check the last picture) lift the front end of the car to one side. Leaving the engine on the deck.
When its out you can pick it up with a couple of mates. Hope this helps
djshaggeh is offline   Reply With Quote
Old 10-01-08, 06:56 PM   #2
vaughanmc
Nova 1.4 T40
vaughanmc's Avatar
vaughanmc has a reputation beyond reputevaughanmc has a reputation beyond reputevaughanmc has a reputation beyond reputevaughanmc has a reputation beyond reputevaughanmc has a reputation beyond reputevaughanmc has a reputation beyond reputevaughanmc has a reputation beyond reputevaughanmc has a reputation beyond reputevaughanmc has a reputation beyond reputevaughanmc has a reputation beyond reputevaughanmc has a reputation beyond repute
I quite like that colour, was this not on ebay a week ago...?
__________________
My Buyer/Seller Feedback
PNG Scotland - Regional Co-Ordinator
Nova 1.2i Spin - On the road
Nova 1.4 Track-Car - Awaiting engine-conversion being finished
Nova 1.4 T40 - Coming Soon
vaughanmc is offline   Reply With Quote
Old 10-01-08, 07:00 PM   #3
djshaggeh
nah, i bought it over a year back from some guy near dover. He ran a BMW dealership and traded it in belive it or not?! It was standard when i bought it.
Old 10-01-08, 07:10 PM   #4
Riggy
NW BOYS
Riggy's Avatar
Riggy has much to be proud ofRiggy has much to be proud ofRiggy has much to be proud ofRiggy has much to be proud ofRiggy has much to be proud ofRiggy has much to be proud ofRiggy has much to be proud ofRiggy has much to be proud ofRiggy has much to be proud ofRiggy has much to be proud of
good work , thats just how i did my first engine swap , but after a few of them , i went and got a proper crane etc, makes life so much easyier
__________________
NOVA REBUILD
MY NOVA new feature
Riggy is offline   Reply With Quote
Old 10-01-08, 07:16 PM   #5
djshaggeh
Thanks mate. When i move into a place with a garage i will probobly get a hoist. Picking up the engine on Saturday, gotta try and squeeze it into the back of the sisters ka, whats the chances? slim?
Old 10-01-08, 07:45 PM   #6
burgo
estate member No 1
burgo's Avatar
burgo has a reputation beyond reputeburgo has a reputation beyond reputeburgo has a reputation beyond reputeburgo has a reputation beyond reputeburgo has a reputation beyond reputeburgo has a reputation beyond reputeburgo has a reputation beyond reputeburgo has a reputation beyond reputeburgo has a reputation beyond reputeburgo has a reputation beyond reputeburgo has a reputation beyond repute
na it will fit . good to see you doing what you said you were gonna bud
__________________
Brown SR Pick-up l Estate Conversion
Originally Posted by bmxalex
Front and rear brown carpets what coulor are they ??
estate up for sale!!
burgo is offline   Reply With Quote
Old 10-01-08, 07:47 PM   #7
Martin
Flashbang Is stil GAY
Martin is a jewel in the roughMartin is a jewel in the roughMartin is a jewel in the roughMartin is a jewel in the rough
when i got one of my xe's from Rexy it only just when in the backo fmy uncles veccy
Martin is offline   Reply With Quote
Old 10-01-08, 08:20 PM   #8
Nick
3 1/2 rods.
Nick's Avatar
Nick is a glorious beacon of lightNick is a glorious beacon of lightNick is a glorious beacon of lightNick is a glorious beacon of lightNick is a glorious beacon of lightNick is a glorious beacon of light
Not much use, but an E16SE definetly fits in a royal mail van !
__________________
PARTS WANTED
E16SE Bottom End
E16SE B+ Spec Head
Fixed Buckets
Interal Shifter / RJ'd Linkage
Doors
Nick is offline   Reply With Quote
Old 10-01-08, 08:30 PM   #9
burgo
estate member No 1
burgo's Avatar
i got a v6 in the back of this easy enough so a valver will go in a ka
__________________
Old 10-01-08, 08:33 PM   #10
Ernie
Ernie has a reputation beyond reputeErnie has a reputation beyond reputeErnie has a reputation beyond reputeErnie has a reputation beyond reputeErnie has a reputation beyond reputeErnie has a reputation beyond reputeErnie has a reputation beyond reputeErnie has a reputation beyond reputeErnie has a reputation beyond reputeErnie has a reputation beyond reputeErnie has a reputation beyond repute
good work fella and thanks for the thumbs up for the wheels.
On the subject of engine's i hade 2 xe's in the boot of my 2.2 diesal civic and a gearbox to 1 side in the back seat area.
I also had chris gsi sat in the front and jen sat in the back.
It drove fine but scraped a few of the speed bumps going out of london.
Oh the joy of a lease car.
Ernie is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin Version 3.5.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
