Results 1 to 1 of 1
Thread: November 2007 : trackdaynova (Updated: 06-11-08)
    Senior User Ste L's Avatar
    Jun 2004
    Sale, Manchester Drives: 106 16v Rallye
    6,490
    Default November 2007 : trackdaynova (Updated: 06-11-08)
    Engine:
    -20XE, Late 2.0 16v DOHC engine
    -Jenvey 45mm tapered throttlebodies with MBE967-ED management
    -Kent AST1612 Inlet & Exhaust Cams
    ... Inlet 260 duration / 10.08mm lift
    ... Exhaust 260 duration / 10.08mm lift
    -Underslung throttle linkage
    -90mm polished trumpets
    -Lightened, skimmed & balanced flywheel (5.1kgs)
    -XE Cream Injectors
    -SBD Coilpack & holder
    -NGK Super-4 plugs
    -FSE Fuel Pressure Regulator (set at 4.5 bar / 62psi)
    -Motorsport inline fuel pressure gauge
    -ITG Mushroom filter
    -Cutom airbox for throttlebodies (track use only)
    -TAS competition solid engine mounts
    -Breather mod carried out
    -Spal 11inch Pacet sucker fan
    -SM alloy swirl pot with Facet redtop fuel pre-pump
    -JIC-6 Braided fuel lines inside the car
    -Mocal 9-row oil cooler
    -Mocal stat-less oil sandwich plate
    -Sierra Cosworth Fuel Pump
    Manfiold & Exhaust:
    -Ashley Group-A Race Competition 4-2-1 overbore manifold
    -Manifold Spec
    ... 1.75" primaries
    ... 2.00" secondaries
    ... 2.25" exit
    -Ashley custom 2.25inch bore pipework mandrel bent 3 box exhaust system
    -2.25inch straight cut tailpipe
    Chassis:
    -1988 Vauxhall Nova Merit 1.2, 3door, hatchback with 31k miles
    -Stitch welded engine bay, boxed out alternator modification
    -14x HH chassis strengthening plates welded in throughout the complete shell
    Transmission:
    -Quaife F20 Straight Cut gearbox (F20SCCR)
    Final Drive Ratio 3.764
    ... 1st Gear 2.54 ~ 55mph
    ... 2nd Gear 1.76 ~ 79mph
    ... 3rd Gear 1.42 ~ 99mph
    ... 4th Gear 1.19 ~ 117mph
    ... 5th Gear 1.040 ~ 134mph
    -ZF Plate Limited Slip Differential
    -Comma AQ3 fluid
    Suspension:
    -Spax RSX432 race coilovers (TuV)
    -Faulkner 7” 350lb front springs
    -Height Adjustable Faulkner 4” 450lb rear springs
    -Eccentric spherical topmounts
    -Lowered tiebar mounts with rosejointed adjustable tiebars
    -Rosejointed custom TCAs
    -Rosejointed steering arms
    -Quaife quick-rack 2.5 turns lock-to-lock
    -PolySport polybushes on rear beam
    -GTE 22mm rear antiroll bar
    -Sparco Upper Alloy strut brace
    Brakes:
    -Front: 280mm x 24mm vented disks at front, Wilwood Dynalite II 4-pot calipers finished in silver, Ferodo DS2500 brake pads with Black Diamond braided brake hoses
    -Rear: Standard drums painted gloss black with Goodridge braided brake hoses
    -Nova GTE brake servo. ATE Super Blue racing brake fluid
    Bodywork:
    -Standard bodywork
    -MK1 ‘one-piece’ bumper & grill
    -Badges & rub strips removed
    -Bumper irons removed for weight saving
    -Bonnet pins holding bumpers on
    -Saloon front round wings, no side repeaters
    -2mm clear polycarbonate windows allround with sliders at front
    -Fibreglass bonnet with bonnet pins
    -Fibreglass tailgate with bonnet pins
    -52mm LED rainlight
    Interior:
    -Stripped out
    -Safety Devices 6 point rollcage (FIA)
    -Corbeau Revolution Bucket Seats (FIA)
    -Red 3" 6point Sparco Pro 2000 lightweight harnesses (FIA)
    -Nova SR 6-dial clocks
    -SPA Speedometer
    -Sparco suede deep dish 3 spoke steering wheel with snap off boss
    -MOMO helmet net
    -FIA cut-off switch
    -2litre FIA Fire extinguisher
    -Calibra internal gearshifter
    Wheels & Tyres:
    -SLICKS: 6J, ET49, 15” Cavalier Cesaro alloys in silver with 19/57-15 Michelin S9B slicks
    -INTERMEDIATES: 6J, ET49, 15" Cavalier Cesaro alloys in black with 195/50/15 Toyo R888s
    -WETS: 6J, ET49, 15” Cavalier Cesaro alloys in black with 195/45/15 Uniroyal Rainsports
    -Bolt to stud conversion
    -5mm wheel spacers at front
    -3mm wheel spacers at rear
    In Car Entertainment:
    -The drive.
    Statistics & Performance:
    - Unladened Weight-729kgs
    - Power at flywheel- 197.7 bhp @ 7620rpm
    - Power at wheels – 175.5bhp @ 7620rpm
    - Torque- 154.1 lb/ft @ 5660 rpm
    Geometry settings:
    - Castor: +4degrees positive
    - Camber: -1.5degrees negative
    - Toe: +1mm toe out
