Due to lack of use, we're going to sell this. Cath bought a new car and the intention was I'd use this on the track but things never got that far! We fitted a quite powerflow exhaust and a new set of Gaz adjustables. The car's hasn't been driven on the road now for about 18 months and has no mot or tax. The carbs need balancing and the brake discs have surface corrosion on them that'll need to come off. I'm finding it hard to get the time to do anything with it so will try to sell as is. If not I'll look at putting an mot on it but will ask more money and advertise it further afield too(only on here at present)
Spec:
C20XE rebored to 2.1
QED Omega 86.25mm race top pistons with race -spec con rod bolts
Lightened and balanced crankshaft
Coscast cylinder head
QED 450-spec camshafts
Race-spec valve springs
Solid lifters
Twin Weber 45mm DCOE carbs
Bailey header tank
Samco hoses
Carbon belt and spark plug cover
Lightened and balanced flywheel
Calibra Turbo clutch
Quiafe ATB
Custom driveshafts
5 as new Speedline Allesio with Toyo Proxies T1R 195/40
288mm discs and calipers from Calibra Turbo
Astra GTE rear disc and caliper conversion
Goodridge braided hoses
Fearless polished rear brace and 4 point roll cage
Cobra Imola seats and Sabelt 4 point harnesses
Carbon clock surround, door cards and rear trim
Digi dash
Momo Race steering wheel
Folded/widened/sealed arches
Seam stich welded engine bay
Body coloured inner arches
De-locked tailgate and doors
Single wiper conversion
Pictures as of yesterday:
As the car stands I'm asking £2750.
