Fully rebuilt C20LET with;
86.5mm Mahle Pistons
Steel Rods
New Bearings all round
Under Piston Oil Squirts for cooling
Z20LET Oil pump and SBS Pickup Pipe
New GM waterpump
All new Gaskets
Cometic 1.9mm Headgasket
XE Cams
Solid Lifter Cylinder head with Piper double valve springs and retainers
Re-seated Valves
New Cambelt kit
10row Mocal Oil Cooler with New hydraulic Lines
200SX Manifold modified to fit Vauxhall Engine and T3 Flange
Rebuilt 0.48 T34 Turbo with 360 bearing
Forge 1bar Actuator
3" Heatwrapped Exhaust Downpipe with flexi
Custom Inlet Manifold with 76mm TB
3" Boost pipes
Big Intercooler
All Silicone hoses (coolant/boost/vac)
AdjustableTurbo Smart Twin Piston B.O.V.
440cc Injectors
4bar Fuel Pressure Regulator
3Bar Map Sensor
Uprated 55l/ph Fuel Pump
New fuel lines
Omex 600 Management with Factory Omex Vauxhall Loom
Mapped by track and road www.tracknroad.com
Lightweight Pot Flywheel
Large Alloy Water Radiator
3 fans (2x7", 1x11")
Helix 4 Paddle Clutch
ARP Flywheel bolts
ARP Rod Bolts
Magnecor Leads
SBD Dizzy Blank
SBD Coil Mount
Ecotec CoilPack
Engine Built by Steve Milton (steveboyslim)
Covered max of 5,000miles.
3 trackdays and 10 runs at Santa Pod this year
£3750
