hi guys was wondering if i run vectra v6 calipers could i run 1.7 cdti meriva 280mm 4 stud discs with them?
Yes mate. But you have to shave a bit of brake pad off on the face so they fit.
nice one mate cheers
Shall i shave them down with a grinder, or is there a different way im supposed to do it?
i used a mach 3 lewi!
Only need about 2mm off each pad. I used a CNC machine.
is there any pads i could buy new and be a straight fit
and how come the discs are tight, they werent tight when they were on vectra hubs n discs.
Probabily because the meriva discs are thicker lewi?????????Originally Posted by LEWI007
they arent theyre 25mm same as the vectra ones
No idea then mate make of pad etc?Originally Posted by LEWI007
