Right since I can't get a bolt in fuel guage sender anywhere is the any other tank I can use that has the twist in type sender?
what engine you running
C14se from a Corsa
I have a brand new spi tank with the twist in sender if your req one cheers browney
Is that the tank that has the pump inside the tank
accessed by under the rear bench?
if you use a spi tank with a mpi pump inside it will work and is prob a better way around it as youve less fuel lines and a swirl pot to so it wont die off on cornering
Ok I'd need to cut the hole out under the rear bench as mine dosnt have it cut out but that wouldn't be a problem
What engine does the mpi pump come from
you can use prity much any mpi pump but i used one from a 2ltr vectra b around year 99 or so youll have to shorten the pipes and prob wont need to cut the hole under the seat just mount it all up from under the car might be better not as most times youll get a smell of petrol through it
Yes buddy it is, i used a walbro pump in a astra gsi cardle but as they say anything will fit in. You need just need a big hole saw![]()
So any vauxhall mpi pump should fit the tank, does the return pipe go to the pump or into an outlet on the tank?
