Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Thread: *HOW TO* make a corsa 2.0 linkage.
    Banned
    Jan 2006
    Hull, drives: The Wife's Celica, Fixes: Mates cars, Saves: for A16VTB
    11,720
    Default *HOW TO* make a corsa 2.0 linkage.
    Ok, i know this is a nova site but it seems alot of users are now building corsa's and asking for info on this. here it is:
    NOTE: i am not going to teach you about welding here, needless to say this guide expects you can weld well. if not get someone who can to do it!
    First off, here’s a list of tools used for this;
    • A hacksaw
    • A marker pen
    • A tape measure
    • A grinder
    • A welder
    • A pair of goggles
    • A pair of gloves
    • A welding mask
    Right, the parts used are;
    • Std Corsa B linkage
    • 1.5 cm flat bar (bought from B+Q)
    • black paint (BBQ paint or anything you have)
    First, get your work area setup, and make sure your welder and grinder work properly. Now get your corsa linkage, and find the U shaped part.
    mark a line right down the middle of the U part, you can see it in the above pic. now cut down the line with the hacksaw, slowly. straightness is very important, it needs to be cut 90 degrees from the edges. get your tape emasure and measure the amount your rear mount is spaced. dependant on your conversion this can range from 0-25mm. this is important, as it determines the amount you need to add to the linkage. now get your flat bar and cut the same length from it, and remember, measure twice cut once. you should now have this:
    Get your welder set up, and test it on some spare bar, you need decent clean welds. i am not going to teach you about welding here, needless to say this guide expects you can weld well. if not get someone who can to do it! DONT FORGET YOUR MASK!! WELDING FLASH IS NOT NICE!! welded it ok? both sides? have a brew, and a hob-nob and you should have this:
    now get your grinder and grind your welds down, but not too far as you may weaken the linkage. USE YOUR GOGGLES! I HAVE THE SCARS ON/IN MY EYE FROM METAL FILINGS, NOT GOOD! like so:
    (half done btw)
    Now paint her up, like so:
    Et voila, you now have your completed linkage. Fit it and align it like the haynes says, by locking the lever and the gearbox. check that you get all the gears. Go have a brew and some hob-nobs.
    Disclaimer.
    This thread is information ONLY. Anyone wishing to perform modifications like this to their own vehicle IS doing so at their own risk.
    Neither myself, PNG Club nor anyone of mine or PNG Club's associates take blame for any potential outcome resulting from the use/misuse of the information contain within this document.
    Rob.
    4th year Membership Scab Club Member Dod's Avatar
    Sep 2004
    Co.Donegal ROI Currently: has no Novas...
    10,652
    You are the Daddy Rob.
    I spent 90% of my money on Drink and Women, the rest I just wasted.
    Banned
    Jan 2006
    11,720
    you knoes it. :D
    Jan 2003
    SOMERSET
    19,510
    No pic or detail of the previous shortened part, not a full guide.
    I only say it like that because I still dont know all of whats involved after reading that guide. Good though.
    Banned
    Jan 2006
    11,720
    what previous shortened part? is it missing a pic?
    Sep 2004
    10,652
    Looks alright to me?
    Rob, is there the clutch entering angle and Heater matrix pipe shortening issue with the Corsa B?
    Banned
    Apr 2008
    suffolk
    6,797
    ok coming from knowing nothing here.
    if your conversion spacer is say 13mm do you add 13mm to the gearbox linkage?
    Banned
    Jan 2006
    11,720
    nope. the bulkhead is 2 inches further back, so it all clears.
    Banned
    Jan 2006
    11,720
    Quote Originally Posted by bmw156
    spot on martin.
  10. #10
    Sep 2004
    10,652
    Just the fire wall to be altered. Would a good slap with the hammer sort it or does it need cutting?
