Results 1 to 8 of 8
Thread: *INFO* Nova Radiator Info
    Bzzzzz Admin Jack's Avatar
    Apr 2003
    Hicksville, GL
    44,173
    4 Post(s)
    Default *INFO* Nova Radiator Info
    You probably already know that Novas came with 4 flavours of radiators (five if you include the minor differences on the two derv rads), but I bet you thought that the 1.6 had the biggest whilst the 1.2-1.4 had the medium and 1.0 the smallest.
    Well not quite. Here's diagrams, sizes and part numbers for the Nova radiator range, including what engine they were fitted to.
    Note that I've added the derv radiators for comparison. As you can see by the size and mounts, these won't fit a petrol chassis.
    90136828 530 x 225 x 32mm
    10S, E12GV, 12N
    90136753 530 x 280 x 22mm
    12ST (early), 13N/NB/S/SB (early), 14SE, C14NZ (late), 16SE, C16NZ
    90298318 530 x 230 x 34mm
    C12NZ, 12NV, 12ST (late), 13N/NB/S/SB (late), 14NV, C14NZ (early),
    90298560 690 x 268 x 38mm
    15D/DT (early)
    90299108 690 x 268 x 38mm
    15D/DT (late)
    Jan 2007
    The Netherlands
    3,381
    diesel rads do fit a petrol nova, only when running a c20.. you have to keep an eye on the engine mount, some clear them, and some dont.
    so it needs a small mod, but they do fit.
    User alan b's Avatar
    Nov 2005
    rep of ireland
    1,061
    ah so my 1.2 rad is the same as a gsi one? as it has the T.C nearer the bottom?
    P N G Adam's Avatar
    Nov 2003
    Stoke-on-Trent
    30,497
    No, it'll be a short type one on "stilts" /\
    Mar 2004
    Fareham, Hampshire
    23,816
    12 Post(s)
    Ah very good info. Never founds pics before to sow people.
    Far from suicidal
    Still I get them tendencies
    Bringing back them memories
    Apr 2003
    Hicksville, GL
    44,173
    4 Post(s)
    Quote Originally Posted by alan b
    If its an early 1.2, yes. Later 1.2s had a different (smaller) rad. Easiest way to check is see if it has stilts on the bottom and position of the TC (bigger ones had them in the middle, smaller ones had them closer to the bottom)
    User Dan Stanley's Avatar
    Feb 2010
    Essex
    797
    Has anyone successfully run a TD rad in a petrol engine setup? i tried with my 20SEH but the inlet and outlet of the TD rad were back to front. It had pipework on it to adapt it, but it still never worked aswell as a normal GSI rad.
    Gold Club Member# 001 Club Member Nova_Tek's Avatar
    Jul 2002
    Hertfordshire..... Builds: ......... Snowplough'd LET
    8,107
    Mines a 1985 12ST. Would this be a early 12ST? If so, then I won't need a rad as it's the same size as a 1.6.
