These are used to align the disc correctly onto a 4 stud hub when doing a big brake conversion to your Nova, Corsa, Tigra, Astra, Cavalier etc.
These can be used with 284mm, 288mm and 308mm vauxhall brake discs.
£11 Posted
Corsa b Chassis Strengthening Kit
£23 Posted
These are marked Saying Left or Right for fitting!
C20XE or C20LET tb plate for custom tophat pipes made from stainless
£12 Posted
Z20Let Turbo Rings, For use when a sillicon hose is put over the inlet of the turbo to smooth the flow of air
Fitted
£11 Posted
Only one ring!
