Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: XE on SBD TB's, Misfiring
    Senior User Club Member scott.parker's Avatar
    Dec 2003
    S-O-A / Warwickshire Drives: Evo Vii
    18,397
    Default XE on SBD TB's, Misfiring
    Right then, went out in the car the other day and it's misfiring, it gets to about 3.500rpm in 3rd, 4000rpm in 4th, 5.500rpm in 5th and then splutters/hesitates slightly, like there is a problem with a sensor, would it possibly be a sensor is loose, so it's vibrating and reading the vibration and then making this transfer into a twitch in the timing/coil spark etc etc?
    If so what sensor would likely be, and location etc.
    Jan 2003
    SOMERSET
    19,510
    Is it still apparent when warmed up thoroughly?
    Senior User Ben's Avatar
    May 2002
    New Zealand
    9,554
    Have you checked its getting good spark and fuel?
    Dec 2003
    18,397
    Plugs are good,clean,all leads are AOK, Injectors are all OK etc.
    As for temperature, it dose it when warm/cold, did it at combe first, reason i think it's sensor is my mate had similar thing on his turbo'd 1600 8v, as the engine was rocking too much etc.
    but it's not that as mines on solids, so though maybe some sensor has rattled loose?
    Nov 1999
    Your wife's bed
    3,760
    Have you tried a different crank sensor?
    Dec 2003
    18,397
    Quote Originally Posted by scott.parker
    No Rick i have not, without sounding dumb, i simply don't know where they are, as i have looked in the Haynes, and cant find them.
    May 2002
    New Zealand
    9,554
    Its bolted in the front of the block by the drivers side mount.
    Nov 1999
    Your wife's bed
    3,760
    It will be just under the drivers side front engine mount. Check the wiring is not broken etc. Worth trying a different one if you can get hold of one for a quick test. Not sure if mbe (is that what management you are on?) is as picky as some (some dont like plastic crank sensors and only the early metal bosch ones).
    Dec 2003
    18,397
    Yeah it's on MBE, i'll check the sensor then, and see if i can buy another for a qucik test.
    Cheers.
    chippy shoulder Admin
    Nov 1999
    Crowland, The Dirty North
    35,414
    18 Post(s)
    I'd say it sounds like a dead coilpack as its doing it at different speeds/loads. if it was the crank sensor I'd have thought it would be cak at a given rpm regardless of the gear etc
