Page 1 of 10 123 ... LastLast
Results 1 to 10 of 98
Thread: Breaking high spec track car all my projets parts avalable plus more its an epic list
    Senior User Count Vaux Alot's Avatar
    Jan 2008
    Bedfordshire/Hampshire
    4,961
    Default Breaking high spec track car all my projets parts plus more epic list PRICE DROP
    As the title suggests I’m breaking my track car project please take the time to have a look through this list and see if anything interests you.
    As I’m not living at home now and I’m some 3 hours away I will only be able to get things sorted when I’m back at the weekend so please have a little patience. I do however have internet access etc so will keep you informed and up to date regally.
    I have taken photo's of what I could get my hands on yesterday, most of the items are detailed in my project thread anyway see here.
    I will say now that the items are either brand new or used but in good condition - the items that are used were brought by myself and haven’t been used since, so you can consider them to be in good condition as I wouldn't have brought them in the first place. I've only stated this as I haven't been able to get pics of everything and I do not want a million questions asking for pictures of things unless it’s really necessary.
    I will also mention that I would prefer collection on all of the items but postage is possible although you will have to wait for me to return to my parents address to do so. This isn’t an issue as I will be home most weekends.
    The items that aren’t photographed are likely to still be on the car so watch for updates.
    It would be easier for me if you direct any interest to my email so i can keep track of everything if you have a specific question PM me and you can have my mobile number
    j_hard@hotmail.co.uk
    Custom wide track front set up all brand new - wide front arms (+50mm each side to suit standard cav, astra, or calibra xe shafts) fully adjustable with new rally design rose joints, on car adjustable tie bars (for castor) with brand new RJ’s and drop mounts for the front panel. +50mm spacers for between the sus leg and hub carrior and +50mm adaptors for the TRE’s
    This kit allows you to run wide on the front with out spacers and also means you can adjust camber, caster, and toe. £450.00
    All the suspension components have been primed and painted black now.
    Custom wide rear beam with welded in spacers +50mm each side with strengthening, relocated and strengthened rear sus mounts £200.00
    Included in the sale - vgc genuine rear drums, brand new genuine rear wheel cylinders, new shoes, new hand brake cable with modification for the extra width, GSI anti roll bar. Its also fully polly bushed including the ARB bush.
    Jan 2008
    4,961
    Uni balls - vgc £90.00
    Original TAS rear hub spacers + 50mm almost impossible to come across £40.00
    Storm single wiper linkage brand new £40.00
    Std XE manifold £10.00
    Standard nova grill brand new (pattern part) £10.00
    spare xe complete but in bits including loom, SFI box etc etc £200.00
    Jan 2008
    4,961
    Spa light weight race mirrors and base plates - the drivers side is bigger than the passengers side to improve vision prov sold
    Jan 2008
    4,961
    Saloon front grill used but genuine £5.00
    Saloon front grill new but pattern £5.00
    Saloon front bumper used but genuine £20.00
    Rolling shell its best to see my wip for full details - A reg with a 6 digit no. plate (usually 7 digit) with the roll cage £1,600.00 OFFERS??
    The Shell has just been repainted and stone chipped underneath (the shell was good before the repaint but all rust was removed prior to paint and its now in vgc) it will include the corsa B bias pedal box with new MC’s and reservoir pots and custom pedal set up, light weight gutted doors, removable ali slam panel, custom fuel filler in drivers B pillar, custom wide FG rear arches fully sealed and foamed, wide FG front arches, turreted rear suspension mounts, raised front suspension turrets, raised steering rack position, full stitch welding, seam sealed and strengthening plates have been welded to the front panel, gear shifter removed and hole plated ready for an internal/quaife jobby, bulk head removed, alternator clearance modification to the O/S chassis rail, windscreen, welded in seat rail for buckets, black jack roof, spare wheel well removed and plated with ali sheet, and its been extensively lightened.
    I will either have to source some standard suspension or the buyer is welcome to bring their own.
    The Shell will obviously have to be tailored away - I can however deliver the shell almost any were (not Ireland) in the UK for an agreed cost.
    Jan 2008
    4,961
    Rear bumper with air vent triangles cut down to skinny size plus x2 quick release bonnet pins £10.00
    Poly carbs full set good condition £200.00
    Opel blitz centre caps to suit steels £20
    Jan 2008
    4,961
    GSI radiator brand new £50.00
    Jan 2008
    4,961
    Heavy duty exhaust wrap – enough to do at least two systems front to rear, the exhaust wrap is coated in silver foil this goes on first, it is then covered by a heat proof silicone tape and is very efficient £40.00
    Custom ali co-drivers foot rest in chequer plate with triangles needs a little finishing if your picky but its 100% usable and complete £60
    Mk5 astra iirc shifter ideal for internal shifter conversion vgc £15
    User Club Member murph-gsi's Avatar
    Feb 2007
    Sligo Ireland
    422
    pm'd
    Jan 2008
    4,961
    Custom aluminium under car air Diffuser £60.00
    Custom aluminium Dash panel £20.00
    Corsa pedal box - standard £30.00
    Custom alternator bracket for fitting twin carbs to an xe allowing adjustment of the alternator up and down for clearance £40
    Cav adj steering column fits nova £30.00
  10. #10
    Jan 2008
    4,961
    In car braided brake lines £100.00
    From front to rear including several elbows, bulkhead fittings, spare braided line (a couple of meters) and fitting for the rear drums.
    AX wiper linkage with nova motor and a nova straight storm wiper arm and new blade £40.00
    350 lb springs brand new 9inch long with a 2 ¼ inch ID £50.00
    Standard XE alternator vgc nearly new only 200 miles £50.00
    2lt 16v claipers - recently refurbed £40.00
    1600 xe ITG throttle body sausage filter £40.00
