Sorry for trying to offer a solution to a problem do it how you want it won't make any difference to me if it goes wrong, i'm sure your diy method will be fine.Originally Posted by Stuart
not my DIY method
but certainly £95 cheaper than yours.... esp as there isnt any need for drilling![]()
Originally Posted by Lee
Ive seen head gaskets go both ways, you can also do the head gasket without mixing oil an water. So many different ways they can fail, however if the head cracks it will go into the header tank as you say, but the gasket can also do that as well.
99% of the time it will be the head an not the core plug, these engines dont usually core plugs its very rare they do.
You'd have much more experience seeing stuff like that than meOriginally Posted by Philsutton
But id still be surprised as the water is under a load more pressure coming up the block so it would have thought it would normally force its way into the oil at this point, rather than vice versa.
Agreed its not a foolproof diagnosis though![]()
Does it work?Originally Posted by Stuart
have you even looked at the link?
Sorry i thought you had tried it....
