a brace like nicks might go round the back of the airbox tho, the bar is sat towards the rear of mounting plate
I'll get the Corsa intake and take it from there
Cheers lads
mine on my 1.2 spi with my green cotten filter touching it Doesnt give me any problems though
Cheers Lee mate
If the Corsa setup doesn't work I'll try a bolt on
i had the same one on my 1.2i with the corsa box and it used to catch on the back ever so slightly so i cut the air box down a bit and plastic welded it so there was enough clearence
So, the one I have should fit ?
No? He just said his used to catch on the airbox?
Old XE track car
Aye I thought the way he put it that it went on but they both touched ?
the corsa box works fine vaughan i had it on mine with no problems/ rubbing at all
Cheers mate I'll see about one then let you know how it goes
