Page 1 of 2 12 LastLast
Results 1 to 10 of 19
Thread: Heaters not working, airlock?
    User atokley's Avatar
    Nov 2006
    116
    Default Heaters not working, airlock?
    Hi,
    I have a c20xe nova, the heaters were working fine on the car and one morning i noticed they stopped working (well only blow out cold air).
    Is it possible i have a airlock in the heater matrix (cant think of any other explanations???) can anyone tell me how to bleed it?
    Thanks
    Andy
    Dr Sideways
    Oct 2006
    SE LONDON/KENT/ESSEX BORDERS
    813
    mine did that, does the hot/cold adjust knob feel easier to turn? in passenger foot well behind centre consul there is a linkage that the knob attatchs to, mine had come undun so was stuck on cold, get under with a torch n turn knob from hot to cold repeatedly seeing whats moving/not moving.
    Nov 2006
    116
    Quote Originally Posted by littlewhiteadrenalinpill
    unfortunately the mechanism is working fine, dont have a clue how to bleed this car tho as im used to jap crap
    Dr Sideways
    Oct 2006
    813
    think run it till hot with heater on n fan on 2, with expansion cap off??
    Senior User chimp007_uk's Avatar
    Coventry, West Midlands.
    4,574
    my gte is exactly the same... it used to be hot, not that the weather is cold, they've stopped working....
    4,574
    anyone know the best way to get rid of air locks in the heaters?
    P N G Adam's Avatar
    Nov 2003
    Stoke-on-Trent
    30,497
    Keep sqeezing the coolant hoses.
    Take the expansion tank cap off, remove the temperature guage sender and let any air escape, once coolant starts to come out of the guage hole, screw the sender back in.
    Like bleeding a radiator in your house..
    Junior User
    Jan 2006
    Tyrone
    67
    head gasket?
    Jan 2006
    Sunderland
    346
    Try checking for an air lock if not it'll be the head gasket!!!
    Take your car to an MOT test station and ask him to check it by putting the emmisions tester into your Header tank water and if carbon is present in your water then its your head gasket!!!
    Aug 2006
    In my house.
    184
    Quote Originally Posted by chimp007_uk
    Do it when the engine is warmish, so that the stat is open but not so hot that your creating more steam voids (bubbles) in the system.
    Point the car up hill.
    Put the internal heaters on flat out and on hot.(again, to reduce the chance of steam)
    Link out the rad stat,so that the fan is running constantly.(as above)
    Remove the header tank cap.
    Fill the header tank to the brim.
    Start the engine and let her tick over, but every now and then, rev the engine, as it takes the increased flow from the water pump to push out the air.
    Hopefully after revving the engine, bubble should appear in the header tank.
