1. Where are all the bits holding on the front and rear Gsi bumpers?
2. How to get the back part of the gsi skirts off?
Cheers
Cheers
hey, the gsi side skirt is held on with 1 clip at the bottom a line of sticky tape, and 2 plastic pop rivest in the end. drill out the plastic rivets with a small drill bit and pull off slowley top to bottom then unclip the bottom clip!!
get a torch and look under the wheel arches for 2 13mm bolts about 5cm away from each other for the frnt bumper,
the rear is held on with 2 bolts on the inside of the boot.
there are plastic things on the sides of the bumpers that keep them straight thaat your have to take off aswel
Remove two small screws on each side (both front and back) holding the bumpers on to the front wing/rear quarter.
Front bumper iron with bumper can be removed from their mounts by removing the grille and 2 small bolts behind the bumper.
Rear bumper can be removed with 2 bolts in the boot.
i found hitting a hedge at 50 is a good way of removing the front one...
Bahahaha class LOLOriginally Posted by novaSR-Ish
