Is it just a case of swapin the old struts witht the new 1s or wat mine are FK automotive an a height adjustable
Cheers Martin
Cheers Martin
where did you get them?
looking for coil overs for ages!! how much?
Rimstyle.com or .co.uk ?355 gota wait 4-5 weeks come str8 from germany
Any1 no i theres any thing else i have to get tp fit these??
Martin, Thats about the long and short of it. unless your coilovers dont have the strut top mountings already attached. If you dont then you will have to get some new ones as the 2.25 inch springs dont fit the original top too well. Once on then you can set the ride heights, a C spanner will make life easier.
Originally Posted by garyc
Were from matey?
the fk's dont have a proper coilover set up on the back, same as the normal style, with an adjuster for the rear spring in the standard place, so im led to believe
ya on the back its just like puttingnormal shocks on butt yhe adjuster is on the spring i've got that far just wonderd about the front coz it dont seem 2 sit right
just fit them like normal shockers then![]()
ok cheers ste all giv i ago wen it stops rainin![]()
Just swap them as stock ones.
