right ive done this and wrote the guide so here goes:
the 1800 TB has a throttle stop screw on it which as it comes off the cav is set too high and will mean it will idle very high (over 2k iirc)
if u look closely at the linkage you'll see it comes down against a screwed rod, on the other end of this screwed rod all u can see is a metal blank, prize it out with sharp thing and u uncover a screw, wind this screw back untill u get sensible idle then get the engine FULLY warm, then continue winding it out until its idling at 900rpm
if u cant get it down that far u have an airleak somewhere, but if u wind the throttlebody down u should be able to hear the leak very clearly..
once the idle is correct you should be good to go, however note that it will idle high on coldstart as the ICV channels are much larger and the fine control isnt quite right
