Results 1 to 7 of 7
Thread: gearbox for 13sr
    Jan 2005
    N.Ireland
    128
    Default gearbox for 13sr
    This mite be a old question but Iam asking it
    because I don't know the answer.
    ( WHAT OTHER GEARBOX'S FIT A 1300 BLOCK.)
    It has a F10 at the mo . dose F13 , F16. etc , etc
    Iam looking for better lift. The F10 I have has a 4.18
    stamped on the end of the box ,this I think is the diff
    final drive. dose anyone know where I can get a 4.29
    final drive.
    Club Member Jim's Avatar
    Nov 1999
    Northamptonshire
    6,218
    The 4.18 stamp does indeed refer to the final drive of the gearbox.
    I take it you are after something with wider gearing? If so, then the final drive number is the key to this. An F13 should fit onto the 1300 block. Try and look for one with 3.74 stamped on the case along with WR (Wide Ratio). This will slow your acceleration, but will increase the top speed between gears.
    FYI, the 4.18fd is usually highly sort after if you don't intend to use it, so it might be worth offering to sell it, unless you wish to keep it should you want a car with quicker acceleration.
    Jim
    WIP
    Small Block Club Member
    Jan 2005
    N.Ireland
    128
    Cheers Jim.
    I was looking for better lift as I was told that you can get a 4.4, 4.3 box out of a old Mrk 1 or Mrk 2 astramaxs van. I not sure if the box is f13,f16 or not. that is why I wanted to know if they fitted the 1300 block.
    I do a bit of racing and need all the lift I can get.
    THANKS
    chippy shoulder Admin
    Nov 1999
    Crowland, The Dirty North
    35,414
    18 Post(s)
    ive got a 4.29 (which owuld be the 4.3) but ive never heard of a 4.4, only a 4.53 as std....
    i assume when you say "lift" you really mean acceleration....
    Aug 2002
    Portsmouth
    681
    you may find you need a bigger clutch and flywheel as the F13 and F16 etc use larger diameter items.
    Jan 2005
    N.Ireland
    128
    Hi stuart
    What type of car did u get your 4.29 gear box out of
    R u using your 4.29 or is it for sale and how much if it is.
    I live in N lreland for postage.
    thanks Gunzi for the advise
    4th year Membership Scab Club Member Dod's Avatar
    Co.Donegal ROI Currently: has no Novas...
    10,651
    Mate, i have SR and GSi boxes available and i'm in Donegal, be a bit handier to get as well.
    I spent 90% of my money on Drink and Women, the rest I just wasted.
