Results 1 to 3 of 3
Thread: paint work
    Senior Member
    Feb 2001
    4,624
    Default paint work
    my cars in need of some paint work and the sprayers I spoke to said that there would be no problem with the small patches of rust on it, they're just surface rust - but when I have tried to paint parts using jelonite and a rust stopping primer, the rust still comes through, will they rid my car of it or will it be just as bad as it was after 6 months, I can't be arsed spending ?400 on something that will not make any improvement!
    Senior Member
    Feb 2001
    4,624
    Default RE: paint work
    If they do a proper job and strip it down enough it should cure it for good, just check hat your getting for your money !!
    Senior Member
    Feb 2001
    4,624
    If it is just surface rust and the sand it out completely you will be ok, if they leave any behind it will come through again. Get a garauntee off them so if it comes back they`ll have to sort it out.
